need parts to build f hydro panther block
  • need parts to build f hydro panther block
    guys gals, im looking forer some parts for 65 hp
    need to ask if you have
    driveshaft from fishing motor for merc 65
    kc 16A CARBS OR ANY CARB SET WITH 1 3/16 VENTURI
    CRANK AND BEARINGS,AND ENDCAPS
    IN NEED OF 45 SS FOOT
    TODD 18N
    TODD 18N
    Hello Todd,
    Call SeaWay Marine at 425-412-4006, ask for Dave Losvar...his direct # is 425-412-5914... SeaWay has complete new 45 SS gearcases. They also specialize in parts for older motors. Dave will understand boat racing needs.
    Or you can also try J. Dub Myers at 206- two seven one- 64 zero zero. He has lots of old parts, and he is knowledgeable in building F Mercury motors.
    Good luck on your project.
      I can make you a drive shaft. Maybe to need one like this for your F Hydro?
      • twb1969
        twb1969 commented
        yes i need one please let me know
        i need filler block with 2 inch elbows
      • twb1969
        twb1969 commented
        we plan on building a stinger set pipes for it
      I misinterpreted your initial post. When you said “F” I was thinking of 1100cc PRO, not Formula E. The engine pictured is not (Even remotely) a legal FE/850. Mine is an 850 Merc, not a 650. My apologies.
      J-Dub
      • twb1969
        twb1969 commented
        i need a drive shaft for a 650 like from a fishing motor
      What is the overall length you need? Are you using a 12mm coupler?
      • twb1969
        twb1969 commented
        18 inches with 12 mm coupler
