I've notice that some turn fins on the leading edge are cut (shaped) on just one side of the fin. Other fins are cut on both sides that form a "v" shape on the leading edge. What are the preferences/benefits for the different shapes?
Turn fin question
We only turn left so.....
Depending on the boat, having a proper fin is pretty important in getting a smooth entrance into the corners. You don't want one that grabs all of a sudden and hooks you right in front of someone or other equally ugly scenarios. I believe the best way to grind a fin is with a little bias to the left, but not totally one sided. If you grind the leading edge symmetrically it is just as likely to grab right as left.
