I want to build a d modified, 750/850 runabout with my son, having a hard time finding any info .I made some calls and emails but nothing for d mod ,found d stock and down info .I would like to build a boat comparable to maybe desilva's 67 d mod he set the records with in pic's or a newer stile that works better ... any info or plans would be helpful thanks in advance
d mod 750/850 runabout plans or info
i haven't looked at the kilo and 1/4 records in long time, haven't seen where the new ones are .. have the d mod and up records got that much faster with the new style boats. the boat in the pic was fast if i remember correctly it was in the 90s and bumped little over 100 with diff motor . can't remember what class motor it was
I believe the DeSilva was Richard Fuchslin's 14 foot 1100 Runabout (two-man) from the '60s and the record speeds he ran were with an 1100 cc 6-cylinder Merc on alcohol (+?). That boat would be way too big and heavy to be competitive in 750 or 850 Mod now. The 750/850 Mod runabout minimum length is 12 feet.
Originally posted by carolinashaker View Posti haven't looked at the kilo and 1/4 records in long time, haven't seen where the new ones are .. have the d mod and up records got that much faster with the new style boats. the boat in the pic was fast if i remember correctly it was in the 90s and bumped little over 100 with diff motor . can't remember what class motor it was
Put on a post "Contact info needed for George Luce, Kelly Kidwell or Derek Gesler".
It looks like someone has built a boat from Luce plans, so he does have plans apparently.
You will want the plans from the original designer.
Good luck on your project.Last edited by DeanFHobart; 04-13-2017, 03:57 AM.sigpic
Originally posted by carolinashaker View PostI want to build a d modified, 750/850 runabout with my son, having a hard time finding any info .I made some calls and emails but nothing for d mod ,found d stock and down info .I would like to build a boat comparable to maybe desilva's 67 d mod he set the records with in pic's or a newer stile that works better ... any info or plans would be helpful thanks in advance
PatLast edited by pat; 04-13-2017, 07:12 AM.
Fred is spot on with the flat deck boat being Fuchlnns 1100 runabout which is the one pictured. However the FER (850) record was set with their Desilva KR which Rich ran 500 with years ago. The FER runabout did run with a 6 mercury on gas which looks like the boat standing up. Derek and Mike both build boats and I too thought the length was 12'6Last edited by 1100-one; 04-13-2017, 02:58 PM.
thanks every one, i was in a hurry when i posted that lol. I should have worded it a little better on what i was wanting . pic was just for attention not necessarily exactly what i was looking for. i said d mod and up because i could mod the plans to fit what i needed . the boat is only going to be a kilo-1/4 boat . just want stable strait line speed... motor will be kinda comparable maybe to a 850 vrp engine that i built from snowmobile cylinders and custom case. on the merc 6 that richered fuchlin set the records with was on alky is what i was thinking also , but it could have been gas not 100% on that
