Extended Tank For a 302 C-Mod Motor
    I build you a Aluminum tank if you want one. Transom mount in or outside or cockpit, Or steering bar you tell me what you want
      Spud -
      I'll take two cockpit tanks, with the nicer cap, the more-shallow-version (square-ish), setup for a return line (fuel pump). Needs to hold the same amount of fuel as a simple, extended 102/302 tank.
      Thanks, John Peeters
      360-435-6445
      http://vitalire.com/
