thrust bracket help
  • thrust bracket help
    im having trouble getting my setup where i want it with the thrust bracket i have...its a btm but i dont know the angle. can anyone tell me who else is building thrust brackets? maybe i could switch to a bracket that goes on the transom instead of bolting too the motor...any advice would be great....hope to see a few of you people at top o...later..nick.
    thrust bracket
    Nick...do you need the angle of the bracket itself or the transom? I just put one on one of my marathon boats and had to use one that was 2 degrees off. It seems to be adequate but I may need to carefully file the yoke if there gets to be too much wear on the neoprene puck.
    Bob
      hi bob......i can get my angles figured out on the boat and bracket i was just curious if a transom mounted bracket might help me gain some setup room or if any other type of brackets on the market might be the solution....thanks for answering and for the help....ill see you at top o...nick.
