I recently aquired a 102 for Ms Julie to test/ race
I really like the idea of having a section of hose run up the side of the boat where it will be easy to see if enough water is pumping. my ? is . If using in -line hose connections will this restrict water flow to a bad level? what size ID hose should be used. would oversize be better? is some level of restriction good? Also what cyl head temp do these run at. I'm not real comfortable about this water issue. I've raced 20 some years, I can see all sorts of trouble with a rookie. even at the APBA ht. restriction I never was sure if I was getting enough water.
Any help would be appreciated.
P.S. we don't intend to be serious compitition here
If you want to answer off-line
sj77g@aol.com
Thanks a bunch
sj77g@aol.com
Thanks a bunch
