head temps?
  • head temps?
    Maybe someone can throw out some ideas... Is the Mychron 4 the only product to check head temps? its for a 250cch. I know other guys are using it, But didnt know if theres another product JUST for head temps.
    sigpicWayne DiGiacomo
    Try aviation supply search. Small aircraft always use them.
    Mark 55P
    Hydroplane Division
      Just got some head temp gages from Trail Tech they the kind that replace the spark plug washer, they also have them in bolt (washer) sizes if perhaps the use or non use of the spark plug washer was not legal. You will need extension cables, they come in 4 foot lengths with two it looks like it will be perfect on a stocker but on a pro/laydown you will need three. They also offer a small tachometer that will work on all kinds of motors.
      I have not tried any of this stuff yet (winter) But I did make mounts for them by attaching them to those spring clamps that we use to build boats that way I can just clip them onto the dash.
      You should be able to get these at any motorcycle shop.
      http://trailtech.net/tto.html
        head temp
        Digatron also makes temp gauges that attach to the plugs. They also make many duel reading devices. I have had good luck on e-bay under go carts. I believe they are made in the Seattle area if you are looking for new.
        Jack711R
          Thanks guys
