Tim, I soak mine in the tub in warm water with Oxy-Clean overnight and they come out pretty darn clean.....real dirty ones might require a couple cycles....
I suggest you follow Daren's methods. You might also want to use a nylon scrub brush on the dirtiest parts. You can also use Spray and Wash on the stubbornest stains, let is soak in real good for at least 5-10 minutes, then scrub.
Hot water, Oxy Clean and elbow grease will make them look a whole lot better.
R-19
Should be Elbow Grease 1st Pat..LOL but yes I've used that method and have had much success!
Reason: spelling
Tim, if you decide to go with a new cut suit consider basic black, it's timeless. Throw string of pearls on and your good to go day our night..............
