Yamato C Mod Gearcase nose cones
  • Yamato C Mod Gearcase nose cones
    What are you guy's doing for streamlining the 102-302 gearcase and plumbing the water? Please post Pictures of your setup if you would.
    Mark
    Mark
    G-11
    125H
    Keep'em Sunny Side Up Boy's!
    we get the nose cones from Lee Tietze and it comes with a 3/8 barb fitting on it..Then you glue it on with West System and then start shaping away..I sent mine to Tom Cronk to play with and make more stream lined. I am curious to see what he comes up with since there is no limit to what can be done.
      Nose Cone
      Mark
      Give me a call,I have the front cones.
      Tom
      863-665-5449
        Mark
        you cant see it in this photo, but we have machined a pick up under the cav plate, test wheel or prop blows a ton of water thru the head,
