OK here we go. The first race the boat and motor were perfect at Elk River. After that the motor has been a slug. I have stuck with the same prop thru everything since you are only suppose to change one thing at a time.
Anyway I have played with fuel mixture and it is so sensitive, one click either way and it is to rich or to lean. It will have trouble getting on plan and have half power all the time if it is to rich and if to lean it will take off and at the halfway point down a strait and then it will just slow down and act like it is at half throttle thru the corners with no acceleration till half way down the strait and then it will take off again.
I have gone thru the engine till I am blue in the face. I have checked the reeds and cleaned the carb but it was about as clean as if it was new. Took the head off and checked the head gasket and pistons. No score marks and very clean. Now I am looking over the exhaust and decided to fill in around the filler block with some more epoxy mixture but it was still sealed on the bottom. I have checked the pipe and header and it has no restriction. Everyone at the race said the motor sounds funny compared to usual. Anyone see anything that might help?
Like I said this sucker worked great at the first race so something has changed but what?? Also this is a FIXED pipe system
