It is finally finished. I got back into the sport last year with two grandkids and building a boat was on the bucket list. Here are fotos of a Sorensen Jackel copy. A kit was purchased from Darryl Sorenson since there are no plans. Found some Alaska Sitka spruce (clear) italian mahogony and planed and ripped out the frame components, routed the necessary pieces. Used a squeegee to apply epoxy on both sides of the plywood, sanded the exterior, applied laquer color trim, clear snap coat urethane, wet sanded, polished and buffed out the finish. Complete with new 15s Sidewinder and prop. This should be fun. Weight is 100 lbs flat with heavy floorboard and heavier bottom since I weigh 132.
Can't wait to try it out. This is the first time I tride to upload pictures.
Bob Smiley
Bob Smiley
