J motor ???????
  • J motor ???????
    I need to know what the gears are in my omc motor gear case and what is the avg. prop pitch and yes i know J prop are given out at races but planning on picking one up just for the kid to use for wheel time. Thanks Mark
    Call Craig Dewald and order one. It is your best bet in the long run. there is no point in finding setups that work with a prop you can not use. you should try to use a prop that is as close to the ones in the box as you can. Graig makes the J props for the APBA
    IMHO
    Look foward to seeing you guys at Burrlington
    "The Coffee Guy"
    TEAM CAFFEINE
    Cranked up and ready to Roll
      Hay kev can"t wait to be in Burlington here is our rig we go testing May 1
      http://www.facebook.com/#!/photo.php...00000424811129
