can someone help me out with some tech questions. I bought my stepdaughter a J boat. Can a J motor later be used as an A or AX? An A dropped back to a J?
J/A/AX motor differences
the dominate motor in J & asx is the Merc 15. it is slated for the axe in A after the 2010 season (Nov, 1 2010) it is weak in A
the omc 15 is the only other option for J/asx. it is for now the dominate motor in A.
"The Coffee Guy"
TEAM CAFFEINE
Cranked up and ready to Roll
Originally posted by Hunter Grimes 4th View Postcan someone help me out with some tech questions. I bought my stepdaughter a J boat. Can a J motor later be used as an A or AX? An A dropped back to a J?Earl11 J........ Dangerous when Wet
Runne Craft- Earl said, " Driving a Runne Craft is like Cheating". Dude, ........ Where's My Boat!
If you are only going to race the J classes...J & AX....
I would not buy a Sindewinder....they are not legal J catagory engines.
If your going to race Stock...then yes you could buy a sidewinder for A"Ask anyone, I have no friends. I do have some people that put up with me and mostly because they like the rest of my family"
Don Allen
A vs J
Both the Jeanrude and merc 15s that are legal for A stock are also legal for J stock, but a restrictor plate behind the carb is added to limit the power. The restrictor plate is purchased from APBA. Good luck to you and your step-daughter.
J/AX restrictor plates
Plates are not expensive, $15 each fom APBA HO. Order 2 of each in case drop one in pond, or lend to someone if they forgot theirs, or sell when she's beyond the class. When she is old enough to race 2 classes(ie: J/AX, or AX/A), it takes approx 10min to change the plates/remove. The plates go in between the back of carb and block - a little fussy to do at first. Have someone show you first couple of times, as you have to remove pullcord recoil housing, but a snap after you've seen it done, or have an extra set of hands to pass wrenches, or pull cord out.Last edited by hydroid; 10-19-2009, 05:54 PM.Stock Outboard Racing!....because other sports,....golf, football, baseball, etc....only require one Ball!
