I turned the wet side up on my hydro this afternoon to wet sand some touch up varnish I brushed on to avoid having to do the whole thing over till winter. I got to lookin & noticed a couple things.
1, the sponsons dont run exactly the same line as the airtraps, they are both out 1/4" to the outside. Being the same Im guessing this is on purpose. Since its not in the water anyway even if not it probably doesnt matter.
2, I clamped a straightedge onto the skeg upwards to hold a carpenters frame square on the bottom & check for square. It was out an 1/8" towards the outside at its bottom. I read the thread on fins & now since I should fix that Im gonna move it slightly out to port & angle the bottom in Im thinkin 1/8 or 1/16. I was practicing turning Saturday & it didnt seem bad as was but I guess you can get used to it too. However it turns out to turn Ill find out soon enough.
Theres been talk about aqua-dynamics on the bottom, sanding w/400grit, etc., what about the air-ed out surfaces, is a wax coated smoothie the way to go or does that just look
'er
