I believe an electronic scoring system with web based real time reporting to be a key element in the sucessful promotion and growth of Outboard racing.
Also, if implemented properly, an electronic scoring system will improve accuracy, results reporting, and give more information while reducing the workload on the scoring comittee.
Electronic scoring systems are in common use in all forms of racing events. Disposable, waterproof, cheap,and reliable Radio Frequency ID (RFID) tags are used at marathon running events, bicycle racing, all forms of motorsport racing and even Radio Controlled (RC) car and boat racing events.
The newest generation of timing equipment uses Magnetic Field sensors instead of Radio Frequency. This is important because RF in the spectrum designated by the FCC for RFID tags has difficulty passing through water. Magnetic fields pass through water with no interference or signal degredation. I am assuming an underwater pickup sensor as an overhead sensor seems difficult and impractical to implement.
Companies like Zoomius http://zoomi.us/ti/zoomius/index.html Champion Chip http://www.championchip.com/ and accuchip http://www.eteamz.com/accuchiptiming...cfm?cat=249418
are all manufacturing proven race timing equipment.
So what are the pros and cons? What would it take to implement this technology into Outboard racing? Do you think its a high or low priority?
Brad Walker
General info about RFID systems:
http://www.rfidjournal.com/article/a...view/4365/2/1/
Brad Walker
