Hi guys, my name is David Bunn and I am first time poster.
I have done a propeller conversion on a 2005 GP1300R waverunner and would love some help getting it sorted out. I looked all over the internet to find what was closest to my setup and I think an inboard hydroplane would have many similar setup features.
If you can help with any of these issues, I would really appreciate the feedback.
Basics....
2005 GP1300R running direct drive 200hp 620 lbs currently running a triton 10 in diameter 4 blade left rotation ssm prop my propshaft is 1in diameter with standard 15splines Best speed so far is 92 at approx 6100 rpms and 60% throttle peak rpms is 7200 and target speed is 105
This is all a work in progress, and things change weekly but below is pic of current setup and a video (have 3 posted on utube)
The problems that I am having is that when cruising, it takes a lot of steering to counteract the torque.
Part could be propwalk as my 10 diameter prop is 2.5 inches above bottom of hull. ( so only 2.5 in of blade in water)
I have been suggested to mount just one rudder on the left side because the drag of it would help offset the right turning. I also think I need more of a bow lifting propeller (instead of stern lifting I currently have) to give more bite with high propshaft.
my questions are...
1 would a left only mounted rudder cause enough drag on left side to help counteract torque? (below is a new rudder I was considering making out of 1/2 aluminum and having water pickup in it, and torque tab on back right)
should i go with just 1 rudder or 2?
2 would a round ear or drag style propeller let stern ride deeper and give needed bow lift? anyidea where i could find one?
3 Currently I have 2 3/8s water pickups which provide plenty of water. One is just raming into engine, and other feeds a shurflow waterpump (for idle speeds) is this how most guys do it, or do i need more or less? I have never run warm or hot with this setup, but dont know what will happen if I go to one rudder (and 1 pickup?)
thanks in advance for any input you offer..... I am doing best I can with this project
current propeller.. ventilates badly out of hole, and doesnt get enough bow lift
current setup, those little wings on rudder were an experiment i did this weekend to try to keep rear planted and offset the lifting of the clever prop and dual rudders.
The wings were very helpful in keeping back in planted, but made my rudders wash out at higher speeds (will redo my rudder mounts to very solid transom mounted rather then just bolted to top deck which allowed movement)
a pass
rudder I drew up to build... think its ok, need bigger or smaller?
a youtube video.. I have 3 posted from this weekend
http://www.youtube.com/watch?v=hr2GSTvXPt0
Basics....
my questions are...
a pass
