HELP with a Rude . . .
  • HELP with a Rude . . .
    Engine: 1987 Evinrude 140 hp V-4 looper.
    Problem: Engine idles *ha* at 2000 rpm. I checked the butterflys and they are closed at idle. All the mechanical linkages seem to be adusted correctly. I looked at the 4 carbs which appear to be composite bodys and didn't see any obvious idle mixture screws. Under the starboard side (right) of the flywheel there was an adjusment screw setup and I fiddled with that. Counter clockwise (out) increased the rpm, clockwise decreased the rpm. But there isn't enough adjustment ot bring the idle down to a sweet purr - best I got was around 1500 rpm. This linkage appears to effect the timing seeing as how it is connected to the timing plate and the adjustment directly affected the low end timing.
    HELP! I suspect the adjustment screw I fiddled with diddles with the low end timing and has little to do with the carb idle adjustment per se. Is the engine base timing out of whack? Is there an idle mix adjustment somewhere? Where should I start?
    Baffled . . .
    carpetbagger
    Bill, Call me in the AM, I get to work about 7 pacific time . I'll walk you through the sink and link prossess.
    707-878-2443
    93-C
    ____________________________
      you work on the 4th?
      dang . . .
      carpetbagger
        Yes I work
        most holidays and weekends
        Call me.
        93-C
          calling . . .
          *bzzzzy* I'll keep trying but Milady is gathering her fishing gear and making boat noises. When she starts tapping the toe and giving me the *glare* I'll have to head for water. If we don't connect I'll try again Thursday.
          carpetbagger
            Send me a PM with your number, I'll call you.
            I'm taking Thursday off, got to work on the race boat
            93-C
              phone #s
              Jeff
              ho 252-638-8618 - going fishing so . . .
              try cell 252-474-4780
              Nice boat you got - built from plans or a kit?
              carpetbagger
                My boat is a JDS Kit. For more info on that go to www.jdsextreme.com You can also click on the link under my "sig" for a slide show of the building and first race season
                Let me know how the adjustment works out !
                93-C
                  ANOTHER ENGINE, ANOTHER TOPIC
                  I AM LOOKING FOR PLUG WIRES WITH THREADED ENDS ON A V4 EVINRUDE, MAYBE LATE 50s VINTAGE. CAN YOU TELL ME WHERE TO LOOK?
                    You can buy the brass threaded ends, Sierra #18-5224, then the bulk Hypalon solid core wire, Sierra #18-5226, and make your own. Plug boot is #18-5750.
                      OEM ( omc ) P/N 510364 List Price: $1.45...I have one in stock.
                      Send me an SASE to:
                      Jeff Akers
                      P.O.Box 98
                      Dillon Beach, CA 94929
                      and it's yours for free
                      93-C
                        Jeff
                        no chance to try the adjustments yet. Told the guy to yank the boat so I can fiddle without hanging over the pristine swamp water of Brices Creek, which has an alligator population. He also needs the nav lights and such rewired - easy task. He's a lawyer and he's gonna owe me a favor or two
                        carpetbagger
