Engine Mounting
  • Engine Mounting
    Just curious how do most decide where to mount the engine on a Hydro.
    Center of hull, center of cockpit, center of air traps ?
    Re: Engine Mounting
    center of air taps
      Re: Engine Mounting
      We use center of cockpit, which is offset.
        Re: Engine Mounting
        I have run a Giles / Hemp / Bezoats and all set up center of air traps. Per Bill Giles
        sigpicWayne DiGiacomo
          Re: Engine Mounting
          Depends on boat and driver. I've set them up with offset cockpit both center of cockpit and center of air trap. My current boat requires center of air trap otherwise it drifts left especially with the 500 mod motor!
          Fast Freddie and ryanbrew57s like this.
          Joe Silvestri
          CSH/500MH
          Dominic Silvestri
          JH/JR
            Re: Engine Mounting
            I would just suggest that you test all the variations to find what is the best for your particular boat and driving style. Good luck with your testing. Even with different propellers it might be better at a particular location.
