25 MOD Project
  • 25 MOD Project
    That looks great… nice looking work.
      I have a NIB Crank.. If interested,, I will send you photos.. $100 + shipping from Florida.
          wow that is an elaborate pipe fabrication, you must be very confident of the design
            Is Brenda good to race it?
                  Looking for internals for B/25ss gear case...16/21 gears,drive shaft,prop shaft,water pump housing
                    Everything except the housing is available….. Call Alan VanWeele at 337-304-0379 or David VanWeele at 386-295-3391 or Frank Erion at 269-720-1337. They have everything you need.
                      I'm curious if you used a calculator or something similar to figure out the chamber volume/distance from the port of the pipe? Or do you just have a model that you know works?
                      The idea of building a Mod motor is very appealing to me, but there's no one local to run against.
                        Still looking for 16/21 gears and all the internals for a A/B mercury foot
                        b.jpg d.jpg ​​​​​​​
                          Still looking for 16/21 gears and all the internals for a A/B mercury foot ;
                          Hello John, Did you try the guys above, in the previous post…. They have what you need.
