Yamato Cooling
    Re: Yamato Cooling
    Yamato cooling
    Ok,Now I get it..and thank you all for your response.I really appreciate it!
    Rich
    Xtoffer72 likes this.
      Re: Yamato Cooling
      Look at how the exhaust cover routes the water, and how you have you discharge hoses routed. Also, take a look at the inside diameter of your discharge hoses. Bigger inside diameter discharge hoses helps keep the motor from creating a vapor lock when the engine isn't pumping that well.
      What do you mean by the inside diameter? Which size hose should be used?
        Re: Yamato Cooling
        Side Note
        As a side note about propellers, cooling, and Yamatos. The second year I went to Depue the Yamato team brought a pro Pugh "replica" boat to the Nationals race and a professional factory driver (with rising sun ascot and all new driving equipment!). The factory team of engineers and crew technicians knew their motors better than we did, with the exception of our "special modifications" to gearboxes, blueprinting, balancing, some shaved heads to APBA minimum "specs" on the 102's and new 302's, ...and our wide variety of props. They were amazed at the speed we got out of their motors, and how high we run them. They spent days trying to get propeller information out of the US racers, with no success, crashed in testing (driver error) , and did not place in the final heat. A few years later they learned about the setup changes we made and our high performance prop sources, and they came back with a new driver to place (I think second) in 350 ccH! I didn't ask them if they had cooling problems in testing... All I know is my 250cc engine steams worse than my 102's, and I have gone to moly-coated pistons to reduce the over-heating effects!
        Semper Fi!
        Al Peffley
        15-R/R-25
          Re: Yamato Cooling
          Yamato cooling
          I sent a BIG thank you to all who responded,But somehow screwed up,it never appeared.
          I now understand the dynamics of whats going on,and why.If it wasn't for YAMATO,we would be where?I guess my remaining question would be,what was the factory YAMATO prop specs?I guess it was all the same for all the racers...What was the Diameter and pitch?
          After all these years,it looks like the 302 is a turkey?What makes it an also ran?
          Many thanks to all who responded...this is really interesting too!
          Anybody like to discuss the black art of propellors?
          Thanks guys!
          Rich Oliver
            Re: Yamato Cooling
            I'll agree that there are many ways to make the 302 pump water better. Look at how the exhaust cover routes the water, and how you have you discharge hoses routed. Also, take a look at the inside diameter of your discharge hoses. Bigger inside diameter discharge hoses helps keep the motor from creating a vapor lock when the engine isn't pumping that well.
            I do think that a lot of guys look at the height of the propeller shaft correctly. You should think about the height of the propeller shaft when you are racing. If you have a boat that airs out really well from front to back then your propeller shaft height is higher than when racing a boat that does not air out well at the transom. This makes a big difference when wanting to pump water all of the time.
            Joe Silvestri
            CSH/500MH
              Re: Yamato Cooling
              Thanks guys!
              Rich Oliver
              The 302 is NOT a turkey.
              bill b
                Re: Yamato Cooling
                Rich O.
                A little advice..........Testing and racing conditions vary greatly. Chances are you will be able to raise the Yamato 102,80,or 302 to a height that may be fine testing but not work under race conditions. You have to keep an eye on the water pumping at a race and possibly have to lower the motor to be 'raceable' in rough race water. A lot of guys burn motors up by not making the adjustment at the races!
                J-Dad
                  Re: Yamato Cooling
                  Matt. Very true. We use a Digatron head temp meter on the hydro. If it gets to 425 degrees you are in the RED zone. Fact is we have not stuck a motor since we started using one.
                  bill b
                    Re: Yamato Cooling
                    cooling modification...........
                    would not a more simpler solution to the "cooling problems" related to the 302's, to just allow the inlet hole in the exhaust snout to be opened up more, versus adding a pickup, which will slow you down? Just amend the dimensions for the hole.........
                      Re: Yamato Cooling
                      I agree....but someone need to do just that, drill theirs bigger and test. Than get the test data to the SORC or come to LA with it so the SORC has facts to make decisions on. What if drilling the hole bigger leads to some other problem....Don't know what... but that is the problem with the SORC, most of the time they don't have the data so they are not willing to just make decisions.
                      Don Allen
                        Re: Yamato Cooling
                        11 years later, newest model Yamato same problem, very very Discouraging to a new guy just getting into the sport
                        Matt Dagostino likes this.
                        • Matt Dagostino
                          Matt Dagostino commented
                          It is discouraging to guys that been in the sport for years also my friend! Hopefully in 2018 the problem will be resolved PERMANENTLY. Stay tuned!
                        Re: Yamato Cooling
                        Seems to me that they were talking about solving the problem the same way that they are talking about now!! Was no one listening 11 years ago??
                          Re: Yamato Cooling
                          Exactly the reason I made a comment to bring it to the top of the forum. So everyone could see that possibly this problem may never be resolved. Might be time to look at another class before I spend anymore money on a "stock" Yamato
                          • Matt Dagostino
                            The Cool Team is hard at work to help solve this for all Yamato Engines. Call your SORC Commissioners and tell them 'i am mad as hell and i am not going to take it anymore' ..................(always liked that movie).
                          Re: Yamato Cooling
                          Sidewinders have impellers...
                          sponsonhead, bill hoctor and 2 others like this.
                          Ryan Runne
                          9-H
                          Wacusee Speedboats
                          ryan.runne.4@gmail.com
                            Re: Yamato Cooling
                            ​hmmm................I posted this 11yrs ago...............................lol
                            Steve Dunn Racing, dt 01 and 4 others like this.
                            • DiGia54D
                              DiGia54D commented
                              Amazing isn't it.....lol
