Yamato engine Temp
  • Yamato engine Temp
    What is considered the optimum Cylinder head temp for a Yamato 302 on a CSH ?
    I think Guedo499 has some data on this. John?
    28-R
      keep it under 400 degrees...380-390 no problems.
      at 3/4" height rule pumping water shouldn't be an issue anyway. But ream out the hole if you're on the edge of pumping water.
      • Flatiron
        Flatiron commented
        Thank you for the numbers Both my CSR and CSH are pumping water pretty decent, I'm rather inexperienced at reading plugs they seem a touch on the rich side. I just got a Temp gauge so I was curious about actual numbers. Thanks Again
      good timing, would this be similar temps for the Y102? maiden run tomorrow
