Eldridge lower unit parts
  • Eldridge lower unit parts
    Does anyone have an input shaft for an Eldridge gearcase laying around? I need one.
    541-441-3257
    Re: Eldridge lower unit parts
    541-441-3257
    maybe.Need a pic. and dimensions
      Eldredge! You might need the correct spelling of the name for a proper parts search online, for example.
      Check Steve Dunn in Conway, SC. He's a regular contributor and once told me that he bought all such Eldredge units that he could.
        Ddalton, Its very similar to a mercury D unit. Instead of a bolt to secure the pinion gear, like the mercury, the shaft is threaded and a nut secures the gear.
        Dwhitford, do you have any contact info? I couldn't locate him.
          only have some stuff for Koing style Eldrige unit
            541-441-3257
            If I remember correctly the shaft stub started as a 55-H shaft. You can make a new one using a square coupling and a 55-H shaft. I have a complete Eldridge unit I will sell for $1,200
              Have this for $1,200
