Hot-rod parts and race engine services
  • Hot-rod parts and race engine services
    I have new Hot-Rod piston change anvil kits with the wrist pin and piston bearing driver for changing pistons on Hot-Rods with a press.
    They are $125 plus shipping
    Make sure your stock 15 Hot-Rod head CC's are legal for nationals!!!
    I have new .031, .025, .020, .017, .015, .012, .010, .005 brass head shims for sale. They are water-jet cut!!! I can have almost any thickness made if needed!
    Thin head gaskets and Thick Head Gaskets!
    NEW complete Lectron Carb Spray shields and carb spray shield mounting rings available
    New OMC fuel pump to Champion Crankcase adaptor plates 1/4" and 1/2" style
    Water PUMPS for OMC A racing gearcase and New style Hot-Rod gearcase
    Hot-Rod power head rebuilds and repair, stock and mod.
    Full machine shop service, need anything made give me a call!!
    I can repair "Rod Throw" damaged on H-R crank journals, depends on type of damage to crank!!
    all new drive shafts are $90.00 each + shipping
    Have new head catchers for stock and mod engines!!
    Have reconditioned wrist-pin hole connecting rods for H-R 64 needle and omc bearing cranks forsale!!!
    2 new omc A drive shafts
    2 new Hot-Rod stock drive shafts
    2 new Hot-Rod Mod Short-Tower drive shafts
    1 of each. OMC 25ss and OMC 25mod drive shafts, for long and short Hot-Rod tower with Hot-Rod gearcase
    1 omc 25ss/mod to Hot-Rod tower adaptor plate.
    New OMC-A / New style Hot-Rod water pumps $60.00
    Have in house Connecting Rod Honing, cylinder boring and honing, for H-R and other outboard racing motors!!!
    Cylindrical grinding services available call for more info!!!!
    Tooling up to regrind Hot-Rod crankshafts, tapers, journals, etc.!!!!
    1 920 229 9253
    thanks
    Darrel
    53w
    BUMP BUMP
      bump bump
        bump bump
